Hi all,
I have a stock 87 grand national and want to upgrade the fuel pump harness (Hot wire) so that I get the optimum voltage to the fuel pump. My question is:
- will the incremental voltage shorten the life of the pump?
- I understand that on the kit instructions it says "be sure to reset your fuel pump pressure regulator, increased voltage to the pump will raise base fuel pressure"
As mentioned; the engine is all stock and the fuel pressure regulator is non-adjustable (made by Bosh) so is really necessary that I switch it out for an adjustable one for this reason?
Any comments would be appreciated.
Tommy
Tommy
