Fuel pump will not prime?
BillyBoost
My fuel pumps have stopped primeing when the switch is turned on. The fuel pressure will not come up and the car is hard to start. I can pump the gas and the car will start and pressure is normal. Once the car is cut off the fuel pressure drops to 0 immediately. Any ideas?
The fuel pump prime is commanded by the ECM. A bad ECM, or just a bad connection, can also cause a failure to prime.
After you check the fuel pump/inj fuse, check the dark green/wht wire going into the fuel pump relay. If the fuse is good and there is no power in the green/wht wire, when you first turn on the key, you have a bad internal computer connection to pin A1 (fuel pump prime circuit).
There will only be voltage in the green/wht wire during the time that the fuel pump prime circuit is active. In other words, it is controlled by the computer and only has power during the first 10-15 seconds after the key is turned on.
I have a bad computer in my spare parts box that did have a failed prime circuit. I solved the problem with another computer from Red Regal T.
Car has Speedpro (FAST) so i guess that rules the ECM out...
I'll check the relay.
Running the car today and noticed that after the car has run a while the prime will activate...it seems to only not work after the car sets a while??
