Dumb question but ill ask anyway. 15 years ago someone installed a homemade hot wire kit. I removed that, and am installing a dual razor fuel pump kit. When i turn on the key it wont turn on, but i can use a jumper wire from alt power to the female gray wire plug by alt. And it works. Only problem is that it then runs continuous with key off. What do i need to do so it works with ignition. Thx a bunch
