Fuel rail feed size question
jmendlik
Anyone know what the saginaw fitting size is on the end of the stock fuel rail that feeds the injectors ?
I wanted to run a -8 fitting on one end and have it screw into the saginaw fitting instead of modifying the rail​
that part discription shows it to be -06AN , he wants -08
Also look for Accel DFI 74748A, DFI 74748B, and DFI 74743H
Yup,
5/8 dowty seal for factory fuel rail feed
1 -8 An to 16 mm x 1.5 male/male adapter (Cut the metric side to fit into the fuel rail as pictured
Forget those alumium AN fittings, go JIC. Can get JIC fitting in brass, steel and SS at a huge savings, even paying for shipping. Who cares if it's blue.
Pronto, you mentioned one can get JIC fittings in SS, which is what I would like to use, but I can't seem to find one with the M16x1.6 thread on the other end.
