Does anybody know where the fuel relay is on a 84 t-type....My car is not sending the voltage back to the fuel pump??
Any info would be much appreciated!
By the way the stuff is still for sale
Always check the fuse first, if you're checking for power for the fuel pump check the rear molex, the pump will only show power for a split second when the ignition is turned on, so you will need two guys.
Sorry guys,
My friend koa is a little slow (HAHA). The car has already been started and runs with the help of holding the throttle down halfway! It wont idle on its own. Were thinking that we have something not set properly causing the timing to be off, or so it seems. We'll get it going soon enough. It sounds really mean with no exhaust though.
Derek
