TR Custom Parts
Mark Hueffman - Owner
- May 25, 2001
OK, here is the deal. Recently converted my 35K GN to a Racetronix double pumper. Came across a deal I could not refuse so converting the car to the double pumper was my winter project. All the parts below are off the TR Custom Parts GN. Paypal payments accept ONLY, please send as a gift or money owed so there aren't any transaction fees. Paypal is trcustomparts@gmail.com
Racetronix hotwire kit for single fuel pump, power wire was cut to splice in Kenne Bell boostapump but has been resoldered - $35 shipped SOLD
Racetronix single fuel pump and stainless steel hanger. Pic with voltmeter set to ohms shows that sending unit for fuel gauge works! This hanger has the heavy duty wiring and regular tube ends that use the stock hoses . $150 shipped, this was bought new in May 2012 SOLD
Stock fuel rails with fuel injection harness. $95 shipped
Kirban all billet fuel regulator. This has been modified with a couple of 1/8 npt ports so I could use steel braided lines instead of the stock vacuum hose. All you need is a barb end fitting with 1/8 npt male fitting to use the stock hose - $75 shipped SOLD
Fitting for adding a fuel pressure gauge at fuel inlet. $15 shipped. SOLD
Stock feed and return fuel lines that attach to front of motor. $120 shipped for the pair
Kenne Bell Boost-a-pump. The best way to increase voltage to your SINGLE fuel pump, especially if you are also running alky injection since it will not affect the alky pump. Includes adjustable dial and hobbs switch that activates the boost-a-pump at 3 lbs of boost. Bought new MAY 2012. $225 shipped. SOLD
