- Feb 18, 2006
Rick.. I like that.. "If fuel can be fed into the tank wot, your vent should be good enough to accommodate the demand of the motor."
Trick would be to make sure the neck was sealed to the gas spicket when doing this.
LOL! you like that? :biggrin:
If the flapper insert in the neck is in place you not venting much back through.
I went through this before. Had the rubber vent line cross over the hard lines when I put the gas tank back up in the car. Could never figure out why the car would not fill with fuel fast. After discovering and fixing the pinched vent line, it will now take the gas nozzle wot no problem.
I also had wot issues with afr's but was real inconsistant. Made it hard to pinpoint the actual cause.
FWIW my o2
