OK just got a fuel pressure gauge. I was getting about 46 lbs with the line off and my scanmaster was reading 90-100 blm everything else was right on. So I lowered it to 43 lbs my blms stayed the same butcar felt faster. So i thought i would lower again to 41 lbs now my blms are at 100-110 and the car felt great should I lower it to 39 lbs to see if i get my blms at idle in the 118-138 range. When I hit wot the blms and int stay pegged at 128. o2 for the last run was 876 no knock @20lbs of boost on pump gas.
