Full Throttle 4" MAS pipe problems
forcefed3.8's
Buckeye Bullet
I just installed the 4" pipe on my car, and it won't idle. It fires up for a second, then dies. I have a Gen 2, set it to 4" Mega MAf or whatever it says. I put my 3.5" LS1 back on, and it runs great. What needs to be done? TIA
This was our problem.......
We had a "few" problems also...........We are "still" working on the problem when we have time. Some cars runs GREAT with the 4in and other ( like ours' ) NOT-so good.
This is a thread on Full Thottle: Idle problems...4in MAF pipe and Trans.plus - Full Throttle Speed Tech Support
Make sure the MAF harness is plugged in correctly (match the wire colors).
Also see what version firmware is in the GENII. You should have 1.07 if using the 4" MAF. It should display the version on power up.
Thanks guys. My Gen 2 is a ver 1.03, I saw on the fullthrottletech site that ver 1.07 can be downloaded. How do I install it into the Gen 2?
