Fuse block ign volt supply
IrvJr
Yest the 3 ign source spots on the left side of my fuse block went dead. Any idea how to fix this?
Maybe a fusible link... When i get home ... I will get my electrical schematics.... And see what feeds them...
Search feature should have the fuses listed.
I believe one is the A/C fuse.
Maybe the other for IGN3 is the ST/BLT fuse.
A quck search should be easy enough.
There are are fuses in the block that control the ign source ports? And i did a search thanks.
check the connector on your ignition switch. unplug and reseat. might be a spread or burnt terminal.
it looks like the ST BLT/ACC fuse (20 amps) feeds those three ports... its located in between them... right below the 2 (immediately to the left of the tail lamp fuse)
Try that and report back.
aaron
