FYI-Minimum Idle Speed
apgnos
Car was running really bad--missing, etc. Went to Chassis
manual, and set minimum idle speed. Voila!!!! (After doing this,
you must re-set TPS. After I set minimum idle speed, I found out that the TPS was at .54 volts, way above the idle reading.
Thought that I might share this with you.
