Garage Sale - lots of junk
Casper's VDO Converter (1) - SOLD (I have one left NIB)
Instrument Cluster - SOLD
I/C Throttle Body Inlet Pipe - SOLD
Oil Filler Tube - SOLD
Rear end cover - SOLD
Transmission Oil Pan - SOLD
Turbo Cover - SOLD
Kirban's MAF Bracket - SOLD
Kirban Brake Dust Shield (4) - These are still available
Everything that has been paid for has shipped this morning.
This is what I have left:
2 Bar MAP Sensor
Air Filter
Air Filter Housing
AM/FM Cassette Player
Ash Tray
ATR Billet Oil Filler Tube
ATR Black Beauty 8mm Plug Wires
ATR Pitbull Chip
Casper's Tach Tap Mating
Charcoal Canister Bracket
Chip
Crankshaft Sensor (Recall)
Downpipe Shield
Fuel Injectors
Fuel Pressure Regulator
IAC
Jack
Oil Pressure Sender
PCV
Plug Wires
Pulleys (Complete Set)
Quick Spool Controller
Radiator Cap
Radiator Overflow Tank
Rear License Plate Bracket
Rear Speaker Hangars (Pair)
Rearview Mirror
Red's Volt Booster
Starter
Stewart Warner 10K RPM Tach
TPS
Vacuum Block
Water Temp Sender
Windshield Washer Fluid Tank
Have these old items for sale still:
2 Bar MAP Sensor
Air Filter
Air Filter Housing
Ash Tray
ATR Pitbull Chip
Chip
Downpipe Shield
Fuel Injectors
IAC
Jack
Oil Pressure Sender
PCV
Plug Wires
Radiator Cap
Rearview Mirror
Red's Volt Booster
Starter
TPS
Vacuum Block
Water Temp Sender
In addition to those items I also have:
TA-49: 8 years old, 3K miles, & I was told it is leaking.
Stock heads: Off of my GN with 80K miles, I replaced them with Champion Irons.
Stock heads: Off of my T-Type, I'm told they were leaking past the valves.
Poston fuel pump wiring upgrade, I do not have the instructions.
Stock front cover, I replaced mine with a piece by Earl Brown.
4 Turbo Tweak Chips
Forgot to mention, make offers to include S&H.
I travel frequently along the I10/I65 between Mobile/Pensacola and NOLA/Baton Rouge. So if you want I can meet along the interstate to deliver.
