Garage sale.
IrvJr
TurboBuick.Com Supporter!
All parts are MAKE OFFER. Hopefully the big stuff can be semi local.
86 BRF trans. stock rebuild with about 30k on it. Worked great when pulled out. Prefer not to ship since it has fluid in it and impossible to get it all out.
dr side and pass side door glass. great shape with 30% tint in good shape.
set of lower door panels from 86 GN, driver quality, not perfect but good
set of lower T Type concert sound door panels in great shape.
set of stock upper and lower control arms with spindles and rotors(those are rusty)
trans crossmember
door sills, good shape not perfect
rear trunk panel outside back window
2 test pipes, one new from Hooker catback, and one used 3"
a/c hard lines
2 primered doors, no rust but seams could be(should be) redone. one has a few quarter size marks of unknown origin
pass door GN black, dent at the top where it meets the window from the body being pushed into but easily fixable
2 primered fenders with GNX vents
2 sets stock rear lower control arms one stock bushings and one with poly bushings
2 sets stock rear upper control arms
2 stock I/C with shrouds
stock 86 GN fan
core support
radiator hold down
2 stock rear sway bars
stock front sway bar.
34mm hollow front sway bar
ATR rear sway bar.
In for A/C hard lines (not bent and in very/exc cond) and radiator hold down pending pics/more info.
Pm'd you
A/C lines SOLD
1 I/C shroud SOLD
New test pipe SOLD
Sorry thats sold. Didnt get that in the update.
Trans still avail, as is most everything else.
