SpoolinUpGN
- Nov 25, 2002
Now, i tried the search feature, but for whatever reason if i do more than 1 word it just shows a blank page... and i think "gas" and "gauge" by themselves would be a bit too general.
Since dropping out my old, leaking tank and replacing it with the typical tank by spearco or w/e this spring, my gas gauge has been reading wrong. It worked perfect before this change. At the same time as the tank, i swapped out for a hotwired walbro 340 that i bought from Mike at Full Throttle. The car runs fine, and the fuel pump seems to have no problems.
However, if I fill up the car (which i havnt been able to do in a LONG time since if you filled it over 1/2 with the old tank it leaked from small holes around the filler neck) the gas gauge does some weird stuff. For example, it goes up rather than down as you drive it, and i mean 50 miles later the thing is pinned past the F. Then, it will move down to 3/4, go back up, go back down, settle at 1/2, and then eventually a 1/4. The last time i let it get down to a 1/4 i was nervous, so i filled it. She took 18.2 gallons, i think thats a bit off. Any ideas guys?
Thanks in advance,
joe
Thanks in advance,
joe
