Gas smell from braided lines
Mike, I am running the aeromotive 15 gal stealth tank with eliminator pump and controller. So far for three years everything has worked flawlessly besides gas smell. And yes it is noisy as hell. But at this point I will not go back to double pumper. I am running -10 feed line to split which then goes -8 to each fuel rail with -8 return. From what I gather from you post I should be able step down to -8 feed line to -6 at split to fuel rails with -6 return with the fragola Teflon lines an fittings?
If you have the #10, go with another #10 in a teflon hose. It just keeps things simple for you. If your going to redo it all, what I mentioned was just a footnote for a replacement. Leave what you have at the motor alone to start off with. Just replace the main feed and return line. That's what I did, and it cured the smell for me.
