Gaskets Gaskets and NOS GN Horn Center
Would you have a turbo to exhaust gasket (believe that's what it is called) the triangle shaped one..
Plenum Gasket $5.00
NOS Inlet Bell Gasket $6.00
NOS Heater water valve..$49
NOS Brake switch..........$99
Stock Throttle body.......$79
New Stainless Heavy Duty Clamp Set $25
New T6 Vinyl Wheel Emblems $19
New GNX Vinyl Wheel Emblems $19
Steering column to firewall gasket...$8.00
Powermaster to firewall gasket.......$7.00
1986 87
Stock throttle body gasket............$2.00
62mm.........................................$2.50
65mm.........................................$3.00
70mm.........................................$3.50
Vacuum block gasket.....................$3.00
Iac housing to throttle body gasket..$2.00
Iac to housing gasket.....................$2.50
Oil drain gasket..............................$5.00
Turbo inlet bell gasket.....................$4.00
Powermaster brake book 55 pages......$15
ALL PRICES INCLUDE SHIPPING IN THE US!!!!
Thanks!
Hi, I'll take 2 of each if you have them.
Plenum Gasket $5.00
Any oil cooler adapter o-rings or turbo oil drain gaskets left?
I would like to get the valve. How much with shipping included. I like deals!
