Buickturbo85
Loves The Buicks
- May 29, 2001
Time to clean out the shelves. Nothing real big or too impressive, just some odds and ends. Figured I'd offer it up here before going ebay. All are 86-87 unless noted.
VDO Boost Gage 2 1/16in (includes tubing and fittings), 0-30psi $25
Kenne Bell Fuel Press Gage with exterior mounting cup 2 1/16in, $25
NEW Coil Pack $50
NEW GM Upper Radiator Hose $20
NEW S-hose (Goes from water pump to front of intake) $15
NEW Aluminum/Chrome Oil Filler/Breather Tube with killer quarter-inch thick "Power 6" emblem (I believe this is from Kirban, but has a real nice emblem on top that I've never seen before) $35
NEW Energy Suspension Poly Trans Mount, part no 3-1108G. Does not fit Turbo Buick but does fit many other GMs $10
Adjustable wastegate actuator (came on a PT-54, I didn't use, is like new) $40
Steering Column Lock Collar with keys from Kirban $35
Kirban "Mystery Theft Deterrent", item 1517, plug-n-play no splicing $15
Turbo Oil Drain pipe with block fitting $15
84-87 Battery Hold-Down $5
Vacuum block with metal vac lines, all are good except 1 which has pinched off end (would still work fine) $10
NEW silicone hose adapter 2.75 to 3 inch, black, came with my KB 70mm TB $5
Stock turbo inlet bell, $5
Trunk blackout trim $20
1-parking light blackout $5
84-85 water heater valve $5
Prices are plus shipping. I prefer money order, but can do paypal.
NEW Coil Pack $50
