i was wondering what everyone has for gauges. also if you can post some pics off where there mounted and how they look. i cant decide what i want to do so the more pics the better.
Knock and boost in the a-pillar, fuel pressure and water temp above the center console, and trans temp and oil pressure below the radio pod. About to add a 3rd gauge for EGT in that center holder above the radio.
Well, the vent right next to the pod is blocked from you, but the one right next to it and the one on the dash by the window provide ample air. You can close that vent completely to allow more air to come out the vents that do directly hit you also.
I believe I got that gauge pod from Ron's Customs in NJ, it has provisions for up to 3 gauges, you just cut the material as needed.
Thanks. I made it myself. The frame is made from aluminum. The sides are thin particle board covered with carpet with GNX louvers on each side so the heat can escape with the heater on. The top front cover is covered with vinyl and has a Ford Escort cup holder thingy. The rear lid is hinged with a CD/DVD case installed under it. It's actually pretty light.
