Hello,
These rods are full custom H-beams and are in good condition. They also have the best rod bolts that money can buy (Carr bolts.) The small end is tapered and there is forced pin oiling from the rod to the piston pin. They have a lot of work and detail into them. I purchased an engine package and these came additionally. I'm not sure on the rod lengths of the Buick V6. These are for a 2.250" crank pin. I have (4) 6.200" long rods and (8) 6.500" long rods.
I took some measurements and this is what I came up with:
(Measurements are very close (+/-.001))
BE diameter - 2.375"
BE width - .888"
SE diameter - .916"
(8) 6.500" long rods ~747 grams (4 are shot peened)
(4) 6.200" long rods ~mass unknown, but less than above
Carrillo can match the rods to complete the sets, if desired. The rods are also machined through the center for pressure piston pin oil, which gives the rods a longer life from lower friction. It is a very high quality custom rod design. They are $378 per rod directly through them, but I would obviously sell them for less than that. I will let them go for $200/rod.
Please contact me at cmac455@gmail.com
BE width - .888"
SE diameter - .916"
