Gbody Seat Question! NEED ANSWER BY TONITE!
not positive on this but when you take seats from a 4door they dont fold forward like a two door for rear passengers
will seats from a 4 door cutlass fit my 86 2 door regal?
The rear seats should fit! If the fronts are both buckets or both bench they should also work. And if you go from buckets to a bench it should also work. If you go from a bench to bucket seats then you will have to mark and drill the holes that would be close to the counsole. hope that helps!
Scot w.
The rear seats should fit! And if you go from buckets to a bench it should also work.
I thought this would have been your answer! If those are what your wanting, MAKE THEM WORK!! :biggrin:
Hi,
I thought was a pretty detailed answer. As the man says, if you require further input, make the seats fit your needs.Good luck!
