Gen 7 and low impedance injectors...
JeffB
is this officially supported? I know on the gen 6's you could "usually get away with it" but I'm wanting to know if the Gen 7 is like the FAST, i.e. designed to work with low impendance injectors even at 100% duty cycle...
Also, are all of these systems sequential or is that an upgrade? I can't find any good docs on what this system can and can't do...
thanks,
Jeff
2 low impedance injectors per each driver. Sequential, staggered batch, TBI... it's all software selectable. Comes with everything including ECM, harness, all sensors, and programming cable/software. Here's info, software, demos, catalogs and stuff. <Link>
Hey DFIguy....when is version 4 of the Calmap software going to be released?
When it's ready...:D
It kinda got put on the back burner for reasons that will become obvious after the SEMA/PRI trade shows later this year. However, it's been tested and we're still tweaking it, so you're probably going to see it sometime next month*.
* Disclaimer: This is about the 5th month in a row that it's been promised "next month", so believe it at your own risk.
