Gen 7 HELP !!!!!!!
Blowen LT1
Well the car is kinda starting Angry!
I can crank it and here is pop ?
If i put the gas all the way to the floor it will start and ideal at 500 RPM and the only why to keep it running is to leave my foot to the floor ? As soon as i lift off the car stalls.......
This is the Gen 7 with a dual sync
I have had it idle at 500 rpm for a bit but when i move the gas it stays the same ?....the throttle is doing nothing ? I have set my low and hi spots...
Any ideas ?
Sounds like you have a big problem somewhere. If you email me the file i will have a look at it. SOUnds like its way lean, did you check all the settings in the config control-s screen? Hows your fuel pressure? DId the map sensor vaccum line fall off?
Email me the program. to norbz@sympatico.ca.
I will make a copy and send it out to you....laptop is out side right now :rolleyes:
thanks
Do you need any other info ?
More info the better, whats exactly done to the car?
