Originally posted by PontiacPaul
OK, guys, first time to post on this particuliar board but you all seem have the best info on ECUs.
What I am trying to determine is what features I need to succesfully go EFI on a turbo pontiac 400 (real pontiac).
Do I need IAC, do I need to be sequential, etc.?
My next question is which ECU is best for my application and why, i.e. Gen 7 or FAST (or something else).
Thanks,
-paul
IAC is not a necessity. I've a friend with a turbo Mustang and he's not using one. Just adjusts the A/F to get it to idle without one.
Sequential isn't really 100% necessary unless you're after then nth degree of power. I've got a friend that's run a 10.02 @ 136mph with batch fire. Sequential is nice, however.
As far as which ECU is best for your situation, research is the only thing that will tell you that. There are several things that each system has going for it.
F.A.S.T. is widely known in the racing world, and odds are that if you go to a track and have a question, you can probably find someone that can help you out with little effort. Gen7 isn't as widely used that I can tell right now.
Gen7 has a few features that I think are really cool. You can go from batch to sequential just by changing a setting in the software. No new box to buy. It also has the ability to learn new sensors. If you have a sensor, O2 for example, go bad on your F.A.S.T. system, you have to call up and give them a number off your ECU. They send you a new sensor and a disk that is the calibration file for the sensor. You have to load this or the sensor won't function correctly. With Gen7, just buy a new sensor and put it on. It auto calibrates to the new sensor.
In the end, you probably can't go wrong with either one. I'm sure as Gen7 grows in popularity (which is may not) you'll be able to find help with it. Either way, you'll make a gob of power with either setup. I'd say find the one that best fits your needs and budget and blast.
