I have an experienced tunner who set up my gen 7 system and tunes the car for me, but he is not always around and I am learning how to use it myself. My question is about my engine stalling when there is a dramatic change in load.The biggest problem is letting off after a greater than 5psi pull adn immediately brake the engine falls right on its face sometimes coming back up to idle speed or completely stalling. The idle also drops below the set idle speed when reving the motor up in gear. It drops about 200 rpm below set idle. I messed around with the throttle follower and some of the other IAC settings, but it didn't really seem to make much difference. I am just looking at what direction I should go with trying to fix this problem, any other tables or anyother configuration screens to adjust?? Everything else seems to be running great and feels healthy. Also for a quick note I am running a 218/218 cam and have -8psi vaccum at idle.
