Gen II main scale and e85
gteatr6
Question, Is it normal to have to bump the main scale on the gen II by 37 to get the blms down to 128 at an idle with e85? I have stock long block, pt67 turbo, lt1 maf, extreme front mount ic, 80lbs injectors, and 100% e85. Another question, is 21 degrees timing for all gears ok, or should I go higher in the low gears and stick with 21 in drive to start tuning?
