Gen II powers up and works but will not allow selection of page or value
Dunebilly
My translator has always worked fine and when I start the car everything powers up but the translator won't change value it just shows battery voltage and rpm as it would but that's all
You can try a master reset. I forget what 2 buttons but it's either the 2 on right or 2 on left.
Hold both buttons down and power up the unit. The display will say " Hold buttons to reset"
Continue to hold the buttons until display reads "all data reset". You will then need to reconfigure per your application. Good luck!
I followed these reset instructions ....no effect do I need to flash my translator? It says it's very 1.35 when I start up
Hold the upper right button down and turn key on and continue holding the button IIRC its like 10 seconds and it will do a full reset.
if the reset doesn't fix it, you can send it in and I can check it out.
Bob
I'll have to it doesn't do a thing. I have a powerlogger I was going to send you a while ago but I bought a second one first but still have this one can i send you both? What address do I send them to
