Hi Rick
I have another question for you, when I'm rolling at a slow speed some times it will stall, even at speed if I lift the throttle it goes pig rich.
I found this in the instructions and figured I would try to tune it out.
MAFLim TPS: TPS value below which MAF Flow is limited to the below settings. MAF Limit: When TPS is below the MAFLimTPS, MAF flow is limited to this. This helps reduce decel richness. MAF /Krpm: Second limiting factor. This setting, multiplied by (RPM/1000), is added to the MAF Limit and the sum becomes the max allowable MAF Flow when TPS is less than MAFLimTPS .
What would be good starting points for the TPS value and MafLimit and do I need to play with the second limiting factor as well.
I have the G chip does that mean I have to cut the MafLimit in half?
