marleyskater420
still needs to learn
- Aug 14, 2004
Previously my gen2 did not read the rpm as the connector was not all the way in the plug. I pushed the connector in, and now it reads the rpm, but cuts out every few seconds. So it will read 800rpm, then quickly go to 0, then go back to 800rpm.
Now the car is also idling so rough that it is dying. I don't know if these are related. If I pull the connector out of the gen2, the car idles fine, but I get a code 34. Now when I plugged the gen2, immediately the car idles rough, and dies within a few seconds, and I still get a code 34. Also, the WB when the gen2 is in, will read upwards of 20-21 AFR, when the gen2 is unplugged, it goes down between 13-14.
The blm's with the gen2 unplugged were 109/110 and would randomly jump to 128, but stayed around 109. With the gen2 plugged in, they were 160.
I have the plug n play adapter for the gen2, an LC-1 wideband, and the extender extreme g chip. I don't know if any of that matters. My maf is a 3.5" ls1.
Any suggestions on where to start? I keep pushing the white wire back into the gen2 connector but it still seems to not be connected fully (as it will randomly go to 0). I also don't know why it goes so lean when the gen2 is plugged in and dies, but when its out it runs fine-ish.
edit: forgot to add that when the gen2 is plugged in and the car dies, the WB gauge still is reading the AFR, and will still give numbers as if the car is on.
Also, hooked up a stock MAF and didn't make any difference.
Any ideas?
Any ideas?
