marleyskater420
still needs to learn
- Aug 14, 2004
At idle in park when I look at the Sensor Monitor screen, and go to WB Corr (which is the Correction used by AFR tracking +/-%) it read 0, but I have my WB hooked up and the AFR tracking set correctly. Is the WB Corr reading simply what % the Gen2 is correcting while it is under AFR tracking? So it would read, lets say, 8% if while you were at WOT and your AFR was off, and the Gen2 corrected 8%?
Also, my gen2 doesn't give the rpm when looking at the sensor monitor screen. What could cause this? My scanmaster reads it just fine.
Lastly, the UserTn, is that just what the overall +/- fuel % that your tune has? Because I have my low load 400-1200rpm set at -15% (80lb injectors) and the UserTn read at -20% when I looked at it. Can anyone explain how this number is created in a way I might be able to understand?
Thank you for the help.
