T
Toma
Guest
We just got a Speed Pro Bank to Bank system with wide band option for our [gulp]421 cu in, xx-trim Mondo Vortech Mustang[/gulp].
We are having some difficulties...
First off it has 77# injectors.
We cannot edit any files unless the Lap Top is connected to the Speed Pro unit.
The VE values in the MAP/RPM table are in the 120's just to idle!!
What should the MAP AE limit be set to, and does this affect the VE values. We have a 2 bar map sensor at the moment.
The AF ratio really fluctuates (from 13.XX to 15.xx) at idle in either open or closed loop. The O2 sensor is only in 1 header tube....should we move it to a collector??
Even though we only bought the unit 2 weeks ago, it came with DOS software....how do we get the Windows software??
Any questions you guys can answer, or problems you can address are much apprecaited...
Thanks,
Toma
Thanks,
Toma
