Ok heres my combo brand new motor billet caps forged pistons stock rods,roller cam roller rockers,very good flowing iron heads,ported intake,6152 precision turbo front mount.alky control dual nozzle.72lb injectors tuning with map sensor,wideband mer setup.On 26lbs of boost a/r set at 11.0 alcohol set to about half the dial.When i roll into the throttle in drive the knock guage goes straght to red.but scanmaster reads about .5 knock.if i hold to it im getting about 5.0 knock,scanmaster says its pulling all the fuel it can at 120.My thumb wheel is on number 1 its lowest setting.Any help would be appreciated.I come from the 4g63 world where 5 degrees is considered ok. Thanks
