regal81455
- Oct 20, 2008
Ok, looks like these upper a's Ive got are setup for some bizarre ball joint (b body spindle?? ) the moog k5208's do not fit so Im going to end up buying new UCA's - should I go GW TLC-88A's or SPC's adjustables? Car will be 60street 40 strip and if it matters I using the S10 brake upgrade...
GW Pros-
bump stop, camber curve correction, and ball joints included
Cons-
not adjustable
SPC Pros-
Adjustable
Cons-
No ball joints ( do they use the k5208's?? ) and no bump stop
So what should I do?? Price seems to be about the same and so is availability.
GW Pros-
Cons-
not adjustable
SPC Pros-
Adjustable
Cons-
