- Nov 4, 2005
ahh memories...
SignUp Now!that is a really nice memory. its sad my car is gone but a lesson learned. dont let other people drive your car!![]()
did anyone ever figure out who had the stolen one?
x2these cars had the exact same overflow tank as a normal t-type/turbo t/grandnational. This goes on a different year model.
That is a stock over flow reservoir in post #39 and was never modified! Also that round part is the Vacuum switch Not the methanol pump.....The pic you have listed in post #39 shows different. It shows the tank is modified for the location of the methanol pump.
Would this be an overflow bottle for one of the methanol test cars?
RARE HURST OLDS/442 + BUICK GRAND NATIONAL COOLANT TANK NOS GM! # 10014451 | eBay
SW.
Not true! It's Not different than the ones on a standard TR, Mine on my car is just like it along with the 4 others I have sitting here. the overflow tanks on any of the methanol test cars were the same as all the rest on TR's NOTHING was/is different. and I would think an overflow tank is just an overflow tank and would have no additional cost just because it was on a methanol test car seeing as it had NOTHING to do with the methanol..I called it modified because it's different than the ones find on your standed Turbo Regal. The one I posted looked like it could be one from one of the methanol cars because of the area left open where the vacuum switch is but now that I think about it like turbofish said its one for the na 3.8 models. I wonder what a NOS overflow tank for a methanol test car would go for?
Did a little more digging and found a lot more / in-depth information. As that little 16 page document barely scratched the surface!
And the cars appear to be numbered a little differently here. And it looks like they sampled the oil of all ten every 1,000 miles in this document. And it says the cars on E85 (or M85 as they referred to it as) were basically just as reliable. Aside from being slightly more difficult to start on cold mornings than their gas brethren!
They refer to it as M85 and NOT E85 is for a reason... They are not the same and sholuld never be confused as one for the other.
The E85 that many of you run is not M85.
Yeah I kept seeing references to formaldehyde and such, but, had no idea why? So what is the difference exactly?? I just assumed that this was an early on variant or designation of today's E85?? However, methanol (wiper fluid / injection spray) is obviously different than Ethanol. It is just that I have never even heard of M85 and made some pretty silly assumptions obviously!!
Thanks!
One is Corrosive as hell the other isn't .. M85 will kill parts pretty quick .. I'd never run this in anything other than a Full out Race car that gets fuel switched often ..
E85 on the other hand isn't corrosive .. partly due to the anti corrosion inhibitors put in the fuel the other is that it is ETHANOL and not METHANOL .
E85 is essentially drinking alcohol + 15% regular gas ... works unreal in Turbo Buicks
