gn and tta parts for sale stage motor also
TurboTA3.8
You wont keep up the pace
TTA engine Fuel lines $60
tta oil cooler setup $80
tta/gn cam sensor $45
tta/gn 200 mile coil pack and module setup $100
tta motor mounts both sides right left engine and frame 1 frame mount need a small repair anyone with a drill and a welder can fix in 15min $150
a/c eliminator idler pulley $60
JW wheel flex plate $185 sale pending
stage 2 balancer hub with crank trigger built in works with stock pulley dont know brand $175 sale pending
tta random technology torque arm $200
aeromotive pro series fuel pump with filter $550
buick engine assy bracket $50
paxton automotive afpr $75
stock tta fuel rail $20
fmic for tta needs a new discharge pipe made for a different then tta stock turbo easy fix at muffler shop to make a ic pipe $800
lakewood rear lca for tta $50
tta oem trans line one line has a small dent near rad atachment point but does not obstruct flow $75
tta radator and fans $150
tta oem full working dash cluster comple $600
tta oem complete engine wiring harness with relays $400
all prices do not include shipping
if you dont think a price is fair make a offer
buick stage 2 off center block, commetic head gaskets , m&a race ported heads with stainless manley valves 1.94 intake 1.60 exhaust ,ngk fr5 spark plugs ,4.005 bore je racing forged pistons ,je racing moly piston rings ,corillo h-beam rods ,buick motorsports 3.58 stroke crank ,comp cam solid roller .572 intake lift .572 exhaust lift duration at .050 230 deg intake 230 deg exhaust lobe seperaton 112 ,arp head studs arp main studs , stage 2 4.1 block ,four bolt mains, roller rockers ,alum valvecovers
$9000.00
I am fairly familiar with these TTA motor mounts, do you have all 6 pieces?
2 Frame pads, 2 metal mounts that mount to the block, and the 2 rubber motor mounts?
could you send me some pictures to wanner@kc.rr.com
thanks
BW
yes they are a complete set ill try to post some photos next week busy this weekend
Do you still have these two items for sale? Let me know. Thanks, Jason
Originally posted by TurboTA3.8
to the top
Need the Coil pack and ignition module
Need the coilpack and ignition module.
Do you have paypal?
Steve Chambers
what model number is the aeromotive pump and filter? Does it come with the inlet/outlet fittings?
the pump is 11102 and the filter is 12302 no fittings come with the units they are the parts only
george
Do you have paypal?
Steve Chambers
i do still have the coilpack and module for sale i take paypal let me know
george
