GN Died while idling
TURBO2
My 86 GN died last night while idling. It had no spark but was running good just before. I found that the Cam Sensor and Coil pack were good and then found the CCCI fuse had blown. I replaced the fuse and it started right up again, but now it keeps breaking down under acceleration. Any ideas what would cause this?
Low voltage to the coil/module?
Wiring fault, shorting to gnd causing fuse to blow?
