GN engine from scratch
jacksorroche
I am wanting to build a GN engine from scratch, using a 109 block from an N/A Regal or Cutless, and the crank from a 4.1. Is there a basic guide on how to do this and on how to aquire all the necessary brackets to change the engine to a single accessory belt drive? I would greatly appreciate any help provided.
where ya been Jack :confused:
looking to go intercooled are you ??
you should drop in from time to time more and more buicks are showing up in our area and were going to try and get some buick gatherings together if winter ever goes away
I've parted out another hotair car since you came by last so if you need something I probly got it
give a call or just drop by Im usually not far away
RED 570-4403
Hay Red
Good to hear from you. I have been out of town a lot, work has got me traveling quite a bit. I'll try and give you a call sometime this week.
