Hey guys, i had all the issues on this car worked out. But after working on a few unrelated parts the car is now acting funny. When i go say 70% throttle the car spools and pulls just fine. If i go WOT the car starts to pull hard until it reaches the max boost, i have it set on around 17lbs. When it gets up to around 17lbs it drops to around 15lbs and my boost gauge jumps around in that area a little, the car feels VERY sluggish and acts almost like its hitting a rev limiter. My scanmaster doesnt show any timing retard so im not sure whats up.
I would suspect that the motor is being flooded with alky.
There are 3 conditions I can see to make this happen in this case;
If you are not running the boost that chip is programmed for, AND, have the alky too high, AND, max out the MAF, you will be flooding the motor.
Bet if you turn the alky down a bit at the lower boost level, it will clean right up.
Technically, there should not be an issue since the alky si progressive and TT is op top of his game.
The reality is that these things do happen.
What is the PAC knob set at?
What if the FP?
What is the MAF reading at the boost/rpm?
I am surprised no one asked that your O2's are at when this happens, or if you have a WB and what the readings are.
A WB and PL file would help a lot.
Of course, I am 1000 miles away and am only speculating since no data was provided . . . . . :tongue:
. . . .The car did this EXACT same thing once before when i accidently left my wastegate solenoid unplugged. So i jumped out and looked and one of the wires was ripped out of its plug in (must have done it while cleaning) this time. So i stuck it back in the connector and used a pair of needle nose to clamp it back in. Tried it but it did the same thing. . . . . .
That is more than likely a complete coincidence. :wink:
