I know Steve(TTA850) is running them but he also has an aftermarket Kmember..
I assume it's possible to run GN mounts in a fbody and use the GN poly mounts correct? Would this make the engine sit up higher? The reason I ask is because it seems to be cheaper to use GN mounts than TTA stuff.
