Here is the list of the rest of my '86-87 GN/TType parts. All parts are used unless otherwise noted!
Transmission:
Art Carr 9" NLU 3500 stall for TH200-4R $400
TH350 BOP strip build with Tbrake, deep alum trans pan, modified GN crossmember for bolt in (a few passes) $800
Art Carr 8" 3500 stall for TH350 (freshly rebuilt/restalled) $800
stock GN D5 12" 2400 stall convertor $50 (for TH200-4R)
new flexplate bolts $10
Ignition/Sensors:
(2) coilpack/module $75 each
new MSD DIS-4 with coil pack interface $300
3 TPS $20 each
2 crank sensors with brackets $25 each
2 cam sensors with caps $60 each
1 WG solenoid $20
1 new EGR solenoid p/n 25526954 $30
1 MAP sensor $25
1 ESSC $40
Engine:
new HRPartsnStuff driver side poly mount $85
new PTE remote oil turbo filter kit $135
new GM front cover ported/blueprinted by Nick Micale with gears and pump housing cover $250
(2) low mileage front covers with gears and pump housing covers $60 each
new 204/214 flat tappet cam $60
new lifters $50
(2) turbo oil drain back lines $25 each
(3) turbo oil feed lines $10 each
'84/'85 ARP head studs $40 (missing 1 nut and 1 washer)
new '86/'87 ARP head studs $80 with Loctite
adj pushrods $40
4 sets of stock pushrods (12) $10/set
4 sets stock rocker arms (pair) $10/set
2 pairs 8445 stock iron casting head complete with valves $50/pair
8 stock GN pistons in good condition $10 each with pins
12 stock GN rods $5 each
(2) aluminum accessory brackets $75 each
2 pair '84-85 valve covers $20/pair
3 stock upper plenums $25 each
2 stock Throttlebodys (no arm or IAC/TPS) $35 each
'84-85 crank sensor (no bracket) $10
3 coil pack support brackets (look like a "U") $25 each
Fuel:
(6) 32# injectors used $50 (I would have them cleaned/flowed costs $60)
adj FPR with 233 base and billet top $50
fuel rail mounted analog fuel pressure guage $20
(3) Bosch 237 FPR $20
(2) Bosch 233 FPR $20
(1) Bosch 233 FPR with billet top (supposedly it is bad) $30
hard line style FPR vacuum piece (goes from FPR to the vacuum line under TB.
(12) stock injectors $30/set
12 injector clips 25 cents each
new in the box stock fuel sock $5
Package deal:
1 '86-87 style valve covers powdercoated black with polished ribs/fins and upper plenum (62mm opening) done as well. With billet driver breather and breather on passenger side looks awesome! Jay Jackson 62mm ported stock throttlebody + RJC powerplate $250
GN trim/interior:
new window felt ($60/pair)
front bumper fillers $50/pair (in very good condition)
NOS driver side front bumper filler $60
GN bumper trim piece $20 each front and rear
new passenger side air dam $20
1 gray pass side computer kick panel (holds computer 2 pieces) nice $40
1 gray pass side computer kick panel (holds computer 2 pieces) ok $25
GN passenger side turn signal housing? Blackout $15
Driver side manually adj mirror with cable $10
Misc:
SMC alchy injection kit with in car controller $300
new 12 pt S&W race cars weld in cage with swing out door bars $200
Casper's Electronics universal GN swap wiring harness $450
Probably some other misc. stuff too!
PM me for pics or any ?'s.
Mark
Transmission:
Ignition/Sensors:
3 TPS $20 each
1 WG solenoid $20
1 MAP sensor $25
1 ESSC $40
Engine:
new lifters $50
adj pushrods $40
Fuel:
Package deal:
GN trim/interior:
Misc:
Mark
