Update as per Drew
WIsh I could edit the original thread!
Here is the list of the rest of my '86-87 GN/TType parts. All parts are used unless otherwise noted!
Transmission:
Art Carr 9" NLU 3500 stall for TH200-4R sold
TH350 BOP strip build with Tbrake, deep alum trans pan, modified GN crossmember for bolt in (a few passes) $800
Art Carr 8" 3500 stall for TH350 (freshly rebuilt/restalled) $800
stock GN D5 12" 2400 stall convertor $50 (for TH200-4R)
new flexplate bolts sold
Ignition/Sensors:
(1) coilpack/module $75 each
1 coilpack $40
new MSD DIS-4 with coil pack interface sold
3 TPS $20 each
2 crank sensors with brackets $25 each
2 cam sensors with caps sold
1 WG solenoid $20
1 new EGR solenoid p/n 25526954 $30
1 MAP sensor $25
1 ESSC $40
Engine:
new HRPartsnStuff driver side poly mount sold
new PTE remote oil turbo filter kit sold
new GM front cover ported/blueprinted by Nick Micale with gears and pump housing cover sold
(2) low mileage front covers with gears and pump housing covers $60 each
new 204/214 flat tappet cam sold
new lifters sold
(3) turbo oil feed lines $10 each
'84/'85 ARP head studs sold
new '86/'87 ARP head studs sold
adj pushrods sold
4 sets of stock pushrods (12) $10/set
4 sets stock rocker arms (pair) $10/set
2 pairs 8445 stock iron casting head complete with valves $50/pair
8 stock GN pistons in good condition tentatively sold
12 stock GN rods $5 each
(2) aluminum accessory brackets $75 each
2 pair '84-85 valve covers $20/pair
2 stock upper plenums $25 each
1 stock Throttlebody (no arm or IAC/TPS)
'84-85 crank sensor (no bracket) $10
3 coil pack support brackets (look like a "U") sold
Fuel:
(6) 32# injectors used $50 (I would have them cleaned/flowed costs $60)
adj FPR with 233 base and billet top $50
fuel rail mounted analog fuel pressure guage sold
(2) Bosch 237 FPR $20
(2) Bosch 233 FPR $20
(1) Bosch 233 FPR with billet top (supposedly it is bad) $30
hard line style FPR vacuum piece (goes from FPR to the vacuum line under TB.
(12) stock injectors sold
12 injector clips 25 cents each
new in the box stock fuel sock $5
Package deal:
1 '86-87 style valve covers powdercoated black with polished ribs/fins and upper plenum (62mm opening) done as well. With billet driver breather and breather on passenger side looks awesome! Jay Jackson 62mm ported stock throttlebody + RJC powerplate $250
GN trim/interior:
new window felt sold locally
front bumper fillers $50/pair (in very good condition)
NOS driver side front bumper filler $60
GN rear bumper trim piece (front sold)
new passenger side air dam $20 (costs $30 to ship!)
1 gray pass side computer kick panel (holds computer 2 pieces) nice $40
1 gray pass side computer kick panel (holds computer 2 pieces) ok $25
GN passenger side turn signal housing? Blackout $15
Driver side manually adj mirror with cable $10
Misc:
SMC alchy injection kit with in car controller $300
new 12 pt S&W race cars weld in cage with swing out door bars $200
Casper's Electronics universal GN swap wiring harness sold
