Prices do not include shipping:
87 water pump pulley 20.00
87 Crank Pulley 20.00
87 Throttle Bracket 25.00
87 Dipstick, if i had to rate it, between 1-10 i would say a 4, 20.00
87 Fuel rail with 42lbs injectors 100.00
87 Harmonic Balancer 50.00
87 Intercooler Bracket 15.00ea, I have 2 of these
87 Upper dog house 20.00
87 Belt Tension 55.00
87 Turbo Shield, has been cut for aftermarket down pipes, , 30.00ea
87 Stock rods 5.00 each, I have 5 of them, they will need to be recon'd
87 Stock rods balanced and mag'd and shot peened, deburred, with .030 pistons, dyno time only, less than 30mins on them. 100.00obo
87 Vacuum lines that goto the throttle body, i have 2 of these, 10.00ea
87 Comp Cams 1pc push rods 8.650length, .080 wall thickness, 40.00
Cam bearings for 87 gn block manufacture TA part# TA1557A NEW in the box, 2 boxes, 20.00ea
87 Turbo drain back tube 10.00
87 Stock exhaust manifolds, cracked in the normal spots, will have to be welded. 40.00
87 Water pipes on top of intake manifold , I have 2 of them, 6.00ea
87 Timing Chain cover, I have 2 of them 20ea.
87 Hall effect sensor , I have 2 of them, status unknown, 20.00ea
ARP MAIN STUDS for Turbo V6, used.30min run time, 25.00
