IronCityTurbo6
- Jan 4, 2005
I purchased this down pipe received it yesterday and installed it last night at boostjunkie racing headquarters.
First:
- Very nice looking piece, welds are perfect definitely better than expected.
- Did not come with installation hardware or cap for cut-out (which I knew)
Installation:
- The flange did not line up with the holes on my stock turbo Solution: Ream out all holes a good bit. READ ON
- Since I had to supply my own hardware I chose round internal hex head M8x1.25 thread 1.25" long these were too long so I shorten them to inch and an eighth (thread)
- With the now shorter bolts two of the four would not even go into the holes in the flange, due to clearance with the pipe itself. Solution: ballpene hammer (bottom and top holes)
- Once installed Down Pipe does not hit anything Very good fit.
- Installed cut out, it did not want to line up with my Hooker cat back. I just used good ole elbow grease and started one at a time tightening untill I could start the next one. It worked out ok.
- I was lucky to be working at my friends shop so he had a spare turbine housing laying around. I notice one very important thing
Those of you with big turbos, check the clearance from the outlet of the turbine to the down pipe flange. This one had at least an eighth inch sticking out into the path of the exhaust. I feel this would be a very easy fix, just use a die grinder to get rid of the lip. I am not sure if this is an issue with smaller turbos, I am going to check, by then I just wanted to get done.
So before you start:
-Ream out all four holes
-check bolt to pipe clearance
-If you have an extra housing, bolt it to the DP and check for obstruction
-Be prepared to fight the cut out
All in all I couldn't be happier now that it is on. Stock turbo spools like F**king lightning, its insane how much difference from the stock down pipe elbow to this giant thing.
I'm just waiting for the cap and I'll be totally satisfied. If your willing to work with this pipe then it is totally worth the price. I love it. My car now breaks traction at 40mph, I have a stock turbo, stock intercooler, and 009s.
Thanks again Shawn. I'm smokin that monte on saturday!!!
Later,
Dom
First:
Installation:
Later,
Dom
