GN/TTA Kit
ledzeppac
Are the GN kits the same as the TTA kit.
I imagine the only difference is the size of the hoses.
Will a TTA kit work on a GN easily because I have a chance to get a TTA kit.
Alos explain to me the 3bar map. Is it worth it etc..
Thank Razor
Phil
The tank/low level is different, the feed hose is shorter, the pump outlet fitting is different, and the pressure hose from filter to nozzle is different.
Also most get the TTA kit with the lower dash panel that integrates the controls into the cockpit making stealthier.
Now.. 1 bar=14.7 PSI
A 2 bar sensor reads to 14.7 PSI due to one bar being vacuum, one bar boost. A 3 bar sensor reads to 29.4 PSI since one bar is vacuum and 2 bars are boost.
You need a 3 bar in applications wanting control over 14.7 PSI.
We call a 3 bar sensor a 30 PSI sensor tho technically it only reads to 29.4..
Contact me for the different components.. i'll help ya out.
The TTA comes factory with a 3 bar sensor
ok I am guessing it would be easier to just get a GN kit. Even if a TTa kit is somewhere around 350-375?
Thanks again phil
Yes , by the time you add the tank, level sensor, longer hose's', 3 bar MAP, fitting... your way over.
