GN1 head installation HELP
NC87GN
johnny boost
A buddy and I are getting ready to install a set of ported heads on his 109 block. He has GN1's with the reciever groove cut for FelPRO 1007. However we have no information on what the head studs should be torqued to. Also is there a different torque sequence using GN1's with 1007's? I've also read that people use a light adhesive to prevent water leaks with thse gaskets. They are GN1 14 bolt heads. The gaskets were given to him without instructions. Any help is GREATLY appreciated...
Mike Banas
87GN
Champion head instructions!
Mike. Send me a e amil and all with attach the instructions from Champion (I have them scanned) I'll also give you some tips on using the 1007 gaskets if you want them to be tight!!!
Your using a 109 block, right?
9sec.
