My question is : are the old casting gn1 8 bolt shaft mount aluminum heads any good / worth using on my 4.1 . I would be pushing them at boost levels of 25-33 psi . With 93 n alky. I'm having the heads checked for cracks n leaks first. But even if they do check out to be in good working order I want to know the pros & cons to using these heads. I don't want to use anything that may come back to haunt me . Thanks guys.
