SignUp Now!What would you like to know more? I can take more pictures tomorrow ..You beat me to it Nesis , do you mind sharing some more info and pictures on your work - it looks good .
So,you've moved the side of the push rod hole 1/64" closer to the side of the intake port and this extra 1/64" clearance has allowed you to move your rockers over from where they where in your before picture to where they are in your after picture.I drilled holes ,
3 holes / head (13.5mm) and a push rod does not hit holes.
What looks good? It's easy to move the rockers until their roller tips are centered over their respective valve stems. The problem is that the push rods get moved over as well. The only picture that matters is a picture of the push rods where they pass through the heads assembled on an engine. There is no picture offered for us to see this.it looks good .
You already have the correct shafts. He said that he enlarged the intake push rod holes from 1/2" diameter to 13.5 mm. That's an increased diameter of 1/32". You are 24 washers, 12 rockers,and 4 tubes away from getting what you want. No machining necessary. Push rods perpendicular to cam and rocker shafts. This is the correct way to fix your problem and it's available for the Buick v6. If it weren't for TA performance,this wouldn't be an option. Your push rods will ride in the centers of their push rod holes and your roller tips will be centered over their respective valve stems.Did you have to drill-enlarge the push rod holes..? can you take a picture of the line up , I see you machined new grooves for the end slip rings - what is the actual distance from the existing groove. Did you machine your own spacers..?
They're parts used on Kenne-Bell rocker assemblies that they used to offer when they were into Buicks. They're not available any more.what is the part number for the KB lockable washers..?
