GNS Marker Cover install
JustABuick
Hey everyone,
Just wondering how people installed their GNS marker covers...did you use a razor blade to pop off the amber cover and glue the new lens on? Just wondering if it has to be glued due to sealing/waterproofing.
Thanks,
Kelly
To install our marker light covers you simply remove both screws, Put the GNS cover right over the lens and put the screws back on... They go over the factory amber lens!
Easy peasy! So do you leave the trim piece off, or put it back on (since it doesn't sit flush with the bumper with the cover on)? Or maybe that amber lens trim piece is only on the Turbo Ts? Thanks for the help, Scot!
It simply goes Over the trim piece! It should fit perfectly in the pocket of the marker trim...
Remove the two screws, hold the trim piece from falling, place the marker cover on it in the correct orientation, and then put the screws back in.... Done!
Wow, I am an idiot....:rolleyes:
Thanks again, Scot!
