GNX dash, Tubular Arms
HotAirGN
Looking for a matching pair of front tubular upper and lowers with sway bar provision.
Also A complete GNX Dash setup minus gauges as I have some Autometers I would like to use. Need the mounting panel AVC style, and modified bezel.
I have one of those panels but would need to make holes for the turn signal and lights. Also prefer the look of the AVC lens over the gauges. Have tried cutting some junk bezels to test but not 100% happy with what the total end result will look like.
How's this look Conrad?
I had an AVC in my car I didn’t like how the gauges are not centered in the dash and how the bottoms of the gauges are covered. The AVC lens is just a piece of plexy glass with a pin stripe around it to hide the edge. I have some good pics of it some were if you need them. Plus you better get an extra inner dash support to there is a lot of cutting with the AVC. If my car was here and not in paint I would try to bend you up one.
