Has anyone had experiences with the VDO speedometer gauge in the GNX Gauge Cluster basically going a bit haywire?
The speedo was never dead on for about a year now; it would jump at low speeds and then at highway speeds it would settle in and consistently read about 5mph on the low side.
The speedometer cable was replaced around a year ago since it could be heard grinding a bit, but that didn't change anything with the speedo readings.
And now it's gone all the way bat****, spinning and jumping seemingly with no patterns and never reads anything close to actual at any speeds.
Cruising at highway speeds the speedo will read between 110 and 120 and sometimes falling almost down to zero and then spinning back up again.
The speedo might be over 20 years old now, do these things eventually just wear out like this?
