SignUp Now!3-3/8" for speedo & tach. 2-1/16" for boost, fuel level, oil pressure & water temp.do anyone know the gauge sizes for the worldofmotorworks cluster?
GNX (ASC) Stewart Warner Gauge Cluster, GNX Dashes, WOMW0010 | WorldofMotorworks.com Buick Grand National Parts & AccessoriesDoes World of Motorsports unit come ready to plug in fact harness for that amount?
Here's a WOMW cluster with SpeedHut gauges:
Plug and Play Harness for GNX (ASC) Stewart Warner Gauge Cluster, GNX Dashes, WOMW0014 | WorldofMotorworks.com Buick Grand National Parts & Accessories
Get both of those and it's plug-n-play. I wish that option would have been available when I did my dash. Would have made things a LOT easier.
There is a little more to it than just the cruz .Besides cruz it also takes care of converter lockup, Highway fuel mode, and in the chip there are also some built in knock ignore programs for things like burst Knock retard that needs the VSS signal, It will stay in low gear timing all the time, fan shut-off your fans will always stay on even at high speed at set temp. I think there are a few other things but these are the main ones. Maybe you can get a chip burnt to work around them. I guess you could just add the VSS circuit and read the MPH that it is reading on the scanmaster and only use the speedo for speed and the other things you want.
If you want the look of a GNX thats fine but if it dosnt need to be perfect I would not use the stewert warner guages there are better choices out there. As for puting a set like I have in the car if you can use a wire crimper you can do it. I just solder mine becuse I want to besure it dosnt give me any trouble. If you want to do it I can walk you through it its not bad at all
